Heat issue and flash glitch
Grt_8z
My Zenfone 8 is heating up while using Google maps and the device is gulping the battery.
And the flash is glitchy. At times, when I try to turn on the flash, the UI changes but the flash won't turn on. Either I should turn on and off multiple times or restart (more than once) the device for a proper functioning. This problem extends while using camera as well. When flash is enabled and I take a picture, flash won't work at times.
Appreciate help in fixing these issues.
0 REPLIES 0
