BIG BATTERY DRAIN ON ZENFONE 8 ON ANDROID 12
Vanja1986
Tge battery on my zenfone 8 is draing so fast ni matter what battery mode i use. Im mostly on dinamic and auto refresh and AOD OFF. The battery life is alos very inconsistent. Just using the phone drains the battery very qiuckly. I dont play games on it,aslo the camera app is using alot of battery. Any advice??I just hope they fix this issues with next updates. Eveything else i love on this phone.
26 REPLIES 26
Vanja1986
Rexator
Mine. Unplugd 6 in morning
Way better than mine,i dont know if the battery is defective or the update will fix that. Are you using AOD?
Rexator
No. Not using AOD. All i do is turn off 5G.
landsome
Rising Star II
Rexator
I second that. A small battery bump in my case as well.
wolktm
I upgraded to 12 and vattery usage is tragic.
9h from 4000mAh??!!!
landsome
Rising Star II
wolktm
Did you factory reset?
