BIG BATTERY DRAIN ON ZENFONE 8 ON ANDROID 12
Vanja1986
Tge battery on my zenfone 8 is draing so fast ni matter what battery mode i use. Im mostly on dinamic and auto refresh and AOD OFF. The battery life is alos very inconsistent. Just using the phone drains the battery very qiuckly. I dont play games on it,aslo the camera app is using alot of battery. Any advice??I just hope they fix this issues with next updates. Eveything else i love on this phone.
26 REPLIES 26
Vanja1986
Rexator
Yes its out. Not sure if thats fix the battery but im gonna try it today
How is your battery?does it last from morning till you go to sleep?whats your SOT?Mine battery is very bad.
Rexator
Im gonna check tomorrow. But before i have around 4-5 hours SOT. I hope this help getting better batterytime.but now its around 1hour SOT and down 17%. But i have download much apps and updates. I will tell you tomorrow if its works better
Rexator
Not getting better battery life. Same like before
Vanja1986
Rexator
This is from today,i unplug the phone every day at 10 in the morning
Rexator
Mine. Unplugd 6 in morning
