BIG BATTERY DRAIN ON ZENFONE 8 ON ANDROID 12
Vanja1986
Tge battery on my zenfone 8 is draing so fast ni matter what battery mode i use. Im mostly on dinamic and auto refresh and AOD OFF. The battery life is alos very inconsistent. Just using the phone drains the battery very qiuckly. I dont play games on it,aslo the camera app is using alot of battery. Any advice??I just hope they fix this issues with next updates. Eveything else i love on this phone.
26 REPLIES 26
landsome
Rising Star II
Vanja1986
Did you factory reset after updating to A12?
Vanja1986
andreescul
https://zentalk.asus.com/en/discussion/58860/big-battery-drain-on-zenfone-8-on-android-12
Yves,twice. Now i have downgradesd to Android 11 via Asus support. And sisetem update poped up via OTA in phone settings. Mi first Android 12 update i did manualy via Asus support but now while im on Android 11 again i see update for Android 12 in phone update software settings.
landsome
Rising Star II
Vanja1986
https://zentalk.asus.com/en/discussion/comment/206996#Comment_206996
Sorry, then. For me 12 was a considerable improvement. Battery manager says nothing relevant about what consumed so much power?
Vanja1986
andreescul
https://zentalk.asus.com/en/discussion/comment/206997#Comment_206997
andreescul
andreescul
andreescul
andreescul
How is your battery on Android 12?you updated it on Android 12 over OTA or manualy?Im loosing battery very quickly just by using the phone for tiping or reading some news. Its very inconsistent battery life. 3.5 SOT,sometimes 4 hours SOT. Im on dinamic,and automatic reftesh rate and
