Battery drain - OTHER APPs
vladovegh
Hello, the battery on my phone is draining quite fast even through the night when in ULTRA saving mode. The battery manager says, that the most of the battery is drained through OTHER ("Jiné" in czech). What are these apps and how to disable them?
19 REPLIES 19
Robert_K
2:10H on screen is normal?
Ronzky321
Robert_K
Nope it's not.
For reference I can game for 2.5hrs (90hz) from 90% down to 8%. So that's already 2.5 SOT with loaded GPU.
Anyway, try sending a screenshot showing all of battery usage. Do you happen to have OTHERS in there? Usually it's found at the very bottom of the list and has a high %.
Robert_K
Sure, i've posted it a few comments before.
Ronzky321
Robert_K
My bad. Didn't notice that was you.
I get good SOT with practically all screen-off gestures OFF. Using Advance Battery Profile with CPU and GPU at LOW (except when gaming).
Robert_K
So no one from Asus would like to say something?
