My zenfone 8 flip doesn't power up
Mohamed_Nour
My
Asus Zenfone 8 flip doesn't powerup, I tried different buttons combination Power button + Volume up + volume down . I tried everything but noting works. It suddenly stopped working.
When i plug it to the charger the LED doesn't work as well
I need the data at least
Any suggestions
Thanks
8 REPLIES 8
Falcon_ASUS
@Mohamed_Nour
We apologize for any inconvenience this may cause.
Please check the top right corner and kindly share the serial number and details requested in the PM inbox.
Hello Falcon_ASUS
My phone issue was resolved in a repair shop (He used a technique called CPU Reballing) to fix the phone.
Though there is no authorized Asus center in Egypt the repair shop guy was able to fix the phone because it have same CPU model as other popular Snapdragon phone n Egypt
Thanks for your support
JM1
This also happened to my Asus Zenfone 8 flip.
The phone just died on me. The same situation as you. The phone won't power up, won't charge (no LED activity) and even if I press the power button and volume down button, nothing happens.
It appears that Asus Zenfone 8 flip phones have the same problem (makes me think if Asus intentionally scammed the consumers with this phone).
Hello JM1
It cost me around just $40
Best of luck
