Wifi & Wifi Hotspot connectivity issue with Bluetooth ON
lovin2501
I am noticing since last update that if Bluetooth is on and connected / paired with a device ( in my case it's Bluetooth earphones) , the wifi connection : both wifi Hotspot as well as wifi facing issues in connecting to the wifi network. It takes too long too connect and post connecting also it frequently disconnects & strata showing obtaining ip address.
If I disconnect Bluetooth then wifi works smoothly.
Kindly review and suggest.
Best Regards ,
Vineet Jain
7 REPLIES 7
_jis_
Zen Master III
Now it's clear infact each n every piece of this phone is acting different.
This is just another speculation, the point is that the problems may be related to the questions I ask in the previous post.
My ZF6 is 6/128.
Anders_ASUS
Hall of Fame III
lovin2501
https://zentalk.asus.com/en/discussion/comment/50855#Comment_50855
Wow if u don't have problem then nobody have problem what a great way to analyse the issue?
Please mention which memory version u have i.e ram n storage?
Further please also see the attached
https://us.v-cdn.net/6031231/uploads/243/XRI19PZQL4P8.mp4
screen recording. The wifi again gets disconnected n starts seeking for ip address after Bluetooth is on.
jis had some very good questions. Please reply all of them and I will help you figure out what could be wrong. Please quote this message when you reply
avibamne
I have similar kind of wifi and Bluetooth connectivity issue with ROG phone II, is there any solution available.
