12-08-2019 07:34 PM
12-08-2019 10:11 PM
12-09-2019 08:57 AM
12-09-2019 01:48 PM
nishaanth5000The Type-C ones?Yah I have tried OnePlus earphones, it worked.
12-09-2019 01:50 PM
ColorSageWhat about headphones that have the DAC integrated? I believe my old HTC U11 headphones had the DAC included, rather than being onboard the old phone. Upon connecting them to my old U11, the device would even push firmware updates to the headphones.It can't. Phones with minijacks usually don't support analog audio over USB-C because these lines are wired to a 3.5mm port. You can use USB-C headphones with Zenfone 6 only if they have integrated DAC. Otherwise, you're out of luck and that won't be changed by any update.
