01-13-2021
09:16 AM
- last edited on
01-16-2024
02:08 AM
by
ZenBot
01-13-2021 10:15 AM
01-13-2021 01:23 PM
01-13-2021 05:50 PM
NikhilaggarwalliveIt's better to check with Service centre, and explain the same thing to them, there are already many instances where an update caused damage to Motherboard, probably you will get a replacement of Mboard.Yes... I used the phone after for two days fluently
01-15-2021 03:48 PM
NikhilaggarwalliveFrom your other posts, you seem to have solved the problem. What was that?Please tell us some basic information before asking for help:
- Model Name: Asus 6z
- Firmware Version: A11
- Rooted or not: no
- Frequency of Occurrence: first tine
- APP Name & APP Version (If your issue relates to the app):
I kept my phone on charging but red blinker is not on while charger is working fine. When I click power button only than charging screen come and it gets vanish off again. Please suggest asap what should I do
Urgent - my phone is not charging and not starting
