11-23-2019 01:09 AM - last edited on 01-16-2024 02:02 AM by ZenBot
11-23-2019 03:29 AM
11-23-2019 05:17 AM
VS-KRThere is currently haptic feedback for double tap in the latest build.I think that instead of a single tap, a long press would be better !
(Like if we are unlocking the phone with a fingerprint sesor below the screen ?)
(Can we have the haptic vibration back when we double tap please, I miss it...)
11-25-2019 02:51 AM
cornelisDouble Tap to Wake will not listen to device edges. So if you are tapping towards the side and top edges it won't work. This is intentional as to prevent triggers when just "holding" the device in your hand.I love the Z6 and ZenUi. But I find the "double tap to turn on the screen" quite inconsistent. It usually takes a few tries before the screen actually turns on. And that could be my fault, that I'm not tapping fast enough or the taps are too far away from each other. Therefore I would like to see a new option in ZenUi where you could just tap the screen once and it turns on, kind of like an iPhone or a OnePlus device. Please respond to make me know if it's possible, thanks! And again, love this phone!
Single tap to turn on screen request
11-25-2019 03:23 AM
11-25-2019 07:40 AM
cornelisI know this isn't what you're asking about, but have you tried the setting to allow swiping up to turn on the display?I always press in the center of screen. But consistency is not my request. It's to have a single tap option. Will you at least consider the request? Thanks for reply though.
