Issues that needs fix
kooldude7285
Rising Star II
1. Auto rotation sometimes doesn't work
2. Front camera opens directly when you get video call becomes an issue if in pocket
3. when in call you cannot go to any other screen. screen stays locked on call screen.
4. Auto brightness sometimes doesn't work
5. Free ram is around 1gb which does not look good i have honor 10 with 6gb ram and always get 2.5gb free ram. i don't think optiflex is problem because i already have it off.
6. Low light camera is not up to the mark when compared with other camera with same specs
7 Slow motion 480fps looks below average and are we getting 960fps considering the chip it has.
8. Struggles with with focus when taking macro shots whereas other phones with same lens can handle it much better.
9. There is no option to have multiple users profile.
10. Option to change clock position.
11. Battery life could be better its great though.
12. Camera gets foggy sometimes automatically due to moisture i guess and it happens from inside the lens.
these are few i experienced others can add if any so that asus can fix them. Ear piece lil better now but not sure if it will be updated any further.
51 REPLIES 51
ColorSage
Zen Master I
To defend my thesis I've connected an USB tester to check current and voltage. After a while it peaked at 9.17V and 1.74A. It was stable, with almost no variations. In Accubattery charging current showed varying result from 2700mA to 3200mA (battery ~4020mV). Don't get me wrong, I'm not an electrician but that doesn't sound as something one should exclusively rely on
_jis_
Zen Master III
I see, I am 🙂
I am using Accu​Battery for 3 years on all my devices and in long term it gives you a great results. Of course capacity / health is higher on a new device and lower on an old device. On one of my previous devices which was dead I measured battery itself with proper tools (like in a photo below) and I got practically the same capacity.
https://hype.ru/@na100gramm/kak-proverit-emkost-akkumulyatora-telefona-rzowh71q
https://akkusbatterien.de/android-akku-kapazitaet-testen/
https://forum.xda-developers.com/oneplus-5t/help/battery-health-accubattery-t3735499/post75393509
_jis_
Zen Master III
I see, I am 🙂
I am using AccuBattery for 3 years on all of my devices and in a long term it gives you a great results. Of course capacity / health is higher on a new device and lower on an old device.  I even measured capacity of battery from one of my devices which was dead with a proper tools (like in a photo below) and I got almost the same capacity as from AccuBattery.
ColorSage
Zen Master I
_jis_ said:
I see, I am 🙂
So, that means none of them reach 100% rated charge capacity out-of-box? Accubattery gave me proper results only after atleast a month using averaged value. I was using it with my S6 for almost a year and calculated capacity changed only by -34mAh (considering small battery and at least twice charging per day i find it unreliable). I don't need engineer degree to find it not precise because it's not rocket science. You had your experience, I had mine.
_jis_
Zen Master III
First of all, I apologize for the double post. I replied, but I did not notice that someone had to accept my message first because I included links in the message. So my answer did not appear here, so I wrote it all by heart and sent it again before noticing the acceptance information.
In real ZF6 battery is rated as 4850 mAh
youtu.be/d58neQ6Ewho?t=109
https://youtu.be/d58neQ6Ewho?t=109
If you charge differently each time (with a different charger, via a computer, from a different percent residual capacity - like 20 or 40 or 60%, to a different percent final capacity - like 80 or 90 or 95 or 100%), the estimated battery capacity will always be different. Even a different battery temperature affects the measured capacity.
You can see it in AccuBattery in Health Tab in Battery Capacity graph for all charging sessions.
That's all about it, each time under different conditions you get a different estimated capacity. Therefore, the real one can be approached after many charging sessions.
