Issues that needs fix
kooldude7285
Rising Star II
1. Auto rotation sometimes doesn't work
2. Front camera opens directly when you get video call becomes an issue if in pocket
3. when in call you cannot go to any other screen. screen stays locked on call screen.
4. Auto brightness sometimes doesn't work
5. Free ram is around 1gb which does not look good i have honor 10 with 6gb ram and always get 2.5gb free ram. i don't think optiflex is problem because i already have it off.
6. Low light camera is not up to the mark when compared with other camera with same specs
7 Slow motion 480fps looks below average and are we getting 960fps considering the chip it has.
8. Struggles with with focus when taking macro shots whereas other phones with same lens can handle it much better.
9. There is no option to have multiple users profile.
10. Option to change clock position.
11. Battery life could be better its great though.
12. Camera gets foggy sometimes automatically due to moisture i guess and it happens from inside the lens.
these are few i experienced others can add if any so that asus can fix them. Ear piece lil better now but not sure if it will be updated any further.
51 REPLIES 51
_jis_
Zen Master III
_jis_
aarkayy31 said:
midwej said:
2. After cca 30 days using the AccuBattery, my estimated capacity is 4650 mAh. Is this value correct?
It can't be. Battery doesn't degrade that fast. Asus has promised the battery to be around 4500mah even after 2 years which is 10% degradation.
You probably don't know or use AccuBattery app in person. After using AccuBattery for just 30 days its result on Health tab is not about lost battery capacity, it is about more accurate capacity estimation. If midwej has 4650mAh it is pretty normal, other users on XDA measured the same: 93-94% 4649mAh and 94% 4690mAh.
Try AccuBattery on your ZF6 a post your result here.
For example I measured 95% 4747mAh on my ZF6, but I treat my battery in a special way (50% ~ 90%).
I have 95% 4744mAh on Battery health in AccuBattery Pro 4,5 months after my quoted post.
midwej
_jis_
https://zentalk.asus.com/en/discussion/comment/10423#Comment_10423
At this moment I have 93% 4625mAh
_jis_
Zen Master III
Quick comparison of battery capacity degradation 4,5 months after quoted post:
You: 4625 - 4650 = -25 mAh
Me: 4744 - 4747 = -3 mAh
As I said I treat my battery in a special way (50% ~ 90%).
@midwej could you characterize your battery charging habit?
Whether we are different in something, the battery capacity reduction is negligible in both cases.
midwej
_jis_
First: I think that my new zenfone started with a lower capacity than your.
Second: I travel a lot - during summer I was in Spain and USA where the temperature was about 35-40 celsius.
However, if posible, I also keep my phone between 50-90%
Jeb
Rising Star II
kooldude7285
I 100% agree
