06-04-2020 10:46 AM - last edited on 01-16-2024 12:52 AM by ZenBot
06-05-2020 11:45 PM
Anders_ASUSYeah i tried the airplane mode advice and in 5 hours it went from 82% to 54. And just for the record this is the battery consumption of the last day... If you add up all the numbers you get a 34% total !!! Wich is weird...https://zentalk.asus.com/en/discussion/comment/86509#Comment_86509
The battery stats won't say much since it will only reset when it reaches full battery.
I sounds like you have an app that's highly active in the background. Here are a couple of things you could try.
First of all, restart your device. It solves a lot of issues and your phone will work better if you restart it once per week.
Second, go to system settings -> battery -> powermaster -> auto-start manager and prevent all the apps to auto start that you don't need a notification from.
After this go to system settings -> advanced -> Mobile Manager -> Memory cleaner -> Turn on Super Clean mode -> enter app list and uncheck any app that you must get notifications from -> go back -> open recent apps overview and press clear all.
Restart your phone.
Monitor your battery life over a couple of days and if it hasn't improved then please put your phone in flight mode when you go to bed. If you have lost more than a couple of percent after 8h sleep, then there might be a bug in the system that we have to investigate.
06-06-2020 07:03 AM
06-08-2020 03:35 PM
johnCforVTSHere are my actual AccuBattery stats just for comparison, I have no complaints about battery drain.Thats my accubatery stats... But it shows an overall health from the first day that been installed. The drain cant be showed here ( its about 2-3 days that this is happening so is a small part of the big picture till now) nevertheless even these stats took a hit by the performance of the last 2-3 days. I used to have much better stats with a really harsh usage...
06-08-2020 04:07 PM
06-09-2020 12:26 AM
