johnCforVTS
Yeah sure!
The battery stats won't say much since it will only reset when it reaches full battery.
I sounds like you have an app that's highly active in the background. Here are a couple of things you could try.
First of all, restart your device. It solves a lot of issues and your phone will work better if you restart it once per week.
Second, go to system settings -> battery -> powermaster -> auto-start manager and prevent all the apps to auto start that you don't need a notification from.
After this go to system settings -> advanced -> Mobile Manager -> Memory cleaner -> Turn on Super Clean mode -> enter app list and uncheck any app that you must get notifications from -> go back -> open recent apps overview and press clear all.
Restart your phone.
Monitor your battery life over a couple of days and if it hasn't improved then please put your phone in flight mode when you go to bed. If you have lost more than a couple of percent after 8h sleep, then there might be a bug in the system that we have to investigate.
