Flash light / torch not working
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-23-2021 04:01 AM
Model Name: 6z
Firmware Version: latest
Rooted or not: not
Frequency of Occurrence:
Flash light in rear mode nd torch is not working but it is working on selfie mode.
Model Name: 6z
Rooted or not: not
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-25-2021 02:19 AM
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check for any disturbance from the installed 3rd party apps.
3. If still you face the issue factory reset your phone after
taking a full backup : https://www.asus.com/support/FAQ/1006346/
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-25-2021 11:17 AM
ranathpodemTry to check with SIMMI test and check if torch test gets pass there by following this steps👇Please tell us some basic information before asking for help:
- Model Name: 6z
- Firmware Version: latest
- Rooted or not: not
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Open calculator>press .12345+= >single test>camera flash test>see if flash on rear side works if yes than test is pass
And hence your problem should get solved after you clear system cache or reset your device
But if test fails than there is surely a hardware problem which can only be fixed when you submit your device to nearest service centre.
Note:- please dont forget to backup your important data before you submit your device to nearest service centre as early as possible.
thanks!
