Charging issue
Hi team,
Not sure what can be the issue but when i connect my Asus 6z for charging at first it shows charging in the lock screen instead of fast charging as a result it charges slow after connecting for two three times it shows fast charging.
Can someone please explain why this is happening.
Regards
Rahul.
Bhasky
Rising Star II
rahul.priyadarshi84
Hi team,
Regards
Rahul.
Charging issue
have you recently changed charging port from regular point ? or do you use spike buster / extension card with other plugs in ? if so try at regular port where you use to charge everytime
check with adaptor/cable quality once
victor010
Zen Master III
Hi there, request you to provide us with your device's latest firmware version. You can follow the below instructions to do the same: Settings -- About -- Software Information
raju_cybertec
I am facing same issue one side of ctpye port show fast charging but other side show only charging.
Same thing happened when you transfer data from pc/laptop one side port show your asus drive.
