Calls not received. Texts delayed.
justinleon2113
Hello. Just upgraded to the ZenFone 6 (Edition 30) over the new year and notice that many calls from family and friends are going straight to voicemail. I tested this with a friend in the room, and out of 5 attempts, only 3 made the phone ring. Many important calls for business do not ring at all. I am using Ultra Mobile (T-Mobile MVNO) and have done the usual run-around (reset phone, empty cache, check all settings for fowarding, DND, and such). Even on a fresh install, it is experiencing the same phenomenon. I tried a different phone and it seemed to consistently work...I'll keep testing.
I wanted to see if anyone else had issues with not getting calls or texts (irrespective of carrier) or if it could be just carrier issues for me. I have great coverage in my area, thus it is not like I am roaming or disconnected. Thank you for the help.
159 REPLIES 159
skylerwolfe
Zen Master I
Just had a missed call, meaning the stock dialer didn't ring but my TMobile Digits app did. Normally both will pop up. I have wifi calling turned completely off in the hidden settings, so I don't think that's a fix. Full signal strength BTW. Would be nice if they could tweak the mbn as previously noted to see if turning on voLTE would actually help. I don't quite understand the resistance.
Edit - see addendum below
skylerwolfe
Zen Master I
skylerwolfe
It's possible this might be a false alarm. Yesterday I again had a call which did not pop up with the stock dialer, but did pop up the T-mobile digits app. The previous call (referenced in the message above) did not leave a VM but this one did and it was a pre-recorded message from a congress person. And I "think" I blocked that number in the stock dialer in the past when I got one. I don't know if the call I got referenced in the message above came from the same number as the one yesterday, but I may have incorrectly accused the phone of missing that call when it may have been due to my instructions to block the number, which the Digits app would not know.
justinleon2113
Any update on this? Please? @LP_ASUS , @Anders_ASUS , @CH_ASUS
CH_ASUS
Community Legend II
justinleon2113
Hi
I believe @LP_ASUS has been trying to get help from those of you who are experiencing this issue with logging - this is the absolute best way we can check what is happening (or what isn't) and start ruling out issues , either ASUS' or TMO's.
If possible, appreciate all of your great assistance in this.
LP_ASUS
Community Legend I
justinleon2113
As @CH_ASUS said, I'm still looking for volunteers to see if this fix works for them. If you are willing to help please @ me or quote this post so that I can send the log tool with instructions.
