Answering incoming calls
I keep trying to answer incoming calls by raising my new Zenfone 6 to the ear (just like I did it on my LG 4 before) but it only works maybe 1 out 10 times, instead it just rings on. Any suggestions please?
14 REPLIES 14
_jis_
Zen Master III
When I tested this gesture, I had the same experience. I am not saying that it was functional only in one in ten cases, nor did I count it, but it was very inconsistent.
This is probably related to the issues discussed in this thread:
https://zentalk.asus.com/en/discussion/7473/asus-calling-screen-annoy-screen
Finally, I found a Smart Key option that allows you to answer a call with a smart button. This is 100% functional.
sathish281295
How to minimise a incoming call without end
Another issue: my ZenFone 6 quickly connects via bluetooth to the car stereo so I can use the phone hands free and the sound quality is OK. After a few minutes, however, I can only hear the other party via the phone's own speaker, not the car's loudspeakers. This is again something I never experienced with my LG G4.
kooldude7285
Rising Star II
sathish281295
not possible as of now.. this has been discussed since pie... they say its stock android behavior... not sure if they are going to work it out..
