08-26-2021 01:20 PM
08-31-2021 07:39 PM
remisonl@remisonl
Greetings to all. Faced the problem of Hi-Res Lossless audio output from Apple Music via Fiio Q3 DAC from my Asus Zenfone 5Z smartphone.
In the Apple Music app, all items are set to Hi-Res Lossless output mode. Hi-Res Lossless tracks are playing. But the output frequency of descriting is less than 48kHz as a result - I know that, tk. when the output path is more than 48kHz, on my Fiio Q3 DAC, instead of the blue LED, orange lights up.
I only noticed problems in Apple Music. For example, through the Neutron players (having set it up properly) and Fiio Music (without any settings at all), I can easily output sound over 48kHz. Yes, I even have tracks in DSD through the aforementioned players easily reproduced (on Fiio Q3, the green LED lights up).
It seems to me that the problem lies in the built-in Audio Wizard handler from Asus. I removed it using USB debugging mode, it even disappeared from the list of items in the notification shade, but I think it still processes sound.
There is a Samsung Galaxy S7 Plus Lte tablet. It has absolutely the same settings as on my Asus Zenfone 5Z smartphone. Hi-Res Lossless (> 48kHz) on Apple Music works great.
I really hope for your help 🙂 I've already broken my whole head.
Problems with Hi-Res Lossless audio output from Apple Music via Fiio Q3 DAC and wired headphones.
