07-09-2019 11:49 AM
07-13-2019 10:58 AM
Jei_ASUS posted on 2019/7/12 12:10 Hi l1ghting23, Is auto-rotate enabled when this problem appears?Hello! So.. 1) Is auto-rotate enabled when this problem appears? In quick stettings, Yes 2)Does this only happen on the preloaded calling app or other third party apps as well? I use only preloaded app for calling, it`s version 4.5.4.26_190416 3)Kindly provide your firmware version as well. WW_ZS620KL_90.11.162.72_20190531 4)Before you call, was your phone in landscape mode? No, it was vertical position. 5)About how long was the call? 3-5 min 6)When this happens, is it unable to get back to portrait mode at all? it cant get back even after several seconds. 7)Do you mean you have to get back to normal position only when you press the screen lock key or tap home key? yes, it is. When i hide, and show it again. Thx!!
07-25-2019 02:33 AM
l1ghting23 posted on 2019/7/14 01:58 Hello! So.. 1) Is auto-rotate enabled when this problem appears? In quick stettings, YesHi l1ghting23, Please check your PM for a message I have sent you. Thank you 🙂
