Network and Battery drain Asus 5z
kaleesmach
It seems the network and battery drain happening with the latest updates.
Asus getting worse all of a sudden. I have planned to recommend Asus 7 to my friends,but this making a wrong impact.
Asus fix it quickly 😒
7 REPLIES 7
aanujkumar12332
yes bro same here battery drain fast
Christine_ASUS
Community Legend II
Hi kaleesmach
Thank you for your asking. Kindly try some stay-at-home troubleshooting tips below:
>Network
1. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
2. Please try reset Network: Settings>System>Reset options>Reset Wi-Fi, mobile & Bluetooth
3. Also, please try "the Factory Reset"
Settings>System>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
>Battery Drain
1. After practiced the Factory Reset, enter "Safe Mode" and leave a 100%-charged phone in sleep(idle) mode in a night, then provide me the screenshot of
①Setting>Battery
②Setting>Battery>3 dots on the top"Show app usage"
If the battery works well in "Safe Mode", please check on any disturbance from the installed 3rd party Apps.
kaleesmach
What kind of funny stuff is this 😓 ,Asus 5z shows just gonna last long 3 hrs after 100 % even though I have turned off the network.Is the new Android 10 going from worse to worst
kaleesmach
aanujkumar123321
Sorry to hear that,it's happening after the Android 10 updates.Asus team kindly release a FOTA updates to solve this issue asap
