07-17-2020
11:33 PM
- last edited on
01-16-2024
12:56 AM
by
ZenBot
07-19-2020 02:33 AM
07-22-2020 05:50 AM
Jeronimosame problemInfo:
- Model Name: Asus Zenfone 5 Selfie Pro
- Firmware Version: Not sure but it's Android up to date (July 2020)
- Rooted or not: no
- Frequency of Occurrence: All the time while charging
- APP Name & APP Version (If your issue relates to the app):
I was using my Zenfone 5 selfie pro as usual when it suddenly turned off, it was low on battery but it was >5% so i wasn't expecting that to happen. Then when I connected my charger it showed the charging screen, then it turned off, then showed the charging screen, then turned off and so on... This keeps happening.
Also the LED that indicates if it's charging is off. I tried with other 2 chargers (which worked on other phones) and the same happened.
I have had this phone for about 2 years so maybe it could be that the battery has finally given up, but I would really appreciate some insight into what might be happening.
I would be thankful for any help you can give me, or your experience if you've had this same problem!
My phone was low on battery, turned off and now keeps rebooting while charging.
07-22-2020 05:53 AM
adityapruthi2001i got the same problem and i went to asus service center and they said it was battery problem and they want me to pay 60$. is it possible that your answer is my only solution to my phone prob?Your flex cable connecting sub board to main board might be lossened up. Try fixing that.
07-22-2020 11:13 PM
cruz.jazon69https://zentalk.asus.com/en/discussion/comment/97611#Comment_97611
