05-18-2020 12:38 PM - last edited on 01-16-2024 01:12 AM by ZenBot
05-19-2020 12:57 PM
05-21-2020 04:24 AM
05-21-2020 06:18 AM
Victor0_ASUSVictor, what they are trying to say is that we never had to sacrifice anything to have an acceptable battery consumption. Android 10 is not optimized, those "solutions" you bring would turn our devices on entry-level ones.Please follow below steps may improve battery backup:
1. Enable “Power saver” (Settings > Power management)
2. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
3. Adjust sleep time and brightness (Settings > Display)
4. Boost memory when you see memory consumption is high with no app running,
5. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
05-21-2020 08:15 AM
Victor0_ASUSFollowing ur mentioned steps was never case for 5z before to get good battery backup in oreo as well as pie then why updating to A10 all this is required?Please follow below steps may improve battery backup:
