[5Z] Minor and major battery issues!
Alice_Renaut
The low battery warning option, in the settings, says it will warn the user in 15% and 5%, but warns in 14% and 4%.
The % indicator does not follow in real time, when it is at 12% in an activity for 10 minutes, it goes down to 11%, but from 11% to 10% it does not last 30 seconds. (Numbers given as an example, do not indicate percentage or time accuracy).
Sometimes, I put it to charge with 10%, it jumped to 12%, rising to 13%, immediately when connecting.
The first 10% of battery, after a 100% charge, does not last even the time of the last 3%.
There is a considerable battery drain after the Android 10. (Not shown on Android 9.)
77 REPLIES 77
Debasish_Sahoo
Zen Master I
amitgarde3
https://zentalk.asus.com/en/discussion/comment/122972#Comment_122972
Until n unless we dont come up with some proofs how was asus suppose to fix this battery issue as per my 5z i still have no complaints on .99 version even .99 give much satisfactory SOT i.e. 5 hrs 30min on my 5z so nothing to complain here and due to this i never took this issue with mods mostly but after seeing other users complaining too much we had some users proofs we took it to mods & dont worry asus have started looking into it as there are various reasons of battery drain which is not by system OS but can be due to third party apps or something
For you if drain is too much you are most welcome to factory data reset and m sure you will see the diffrence and than report here your SOT
Thanks!
But you can't deny the fact that battery drain issue is still there and it needs optimization for sure 😉 and I had already sent the logs to mods 🙂
Debasish_Sahoo
Zen Master I
hkorkut
https://zentalk.asus.com/en/discussion/comment/122668#Comment_122668
We have always waited for this during the last two updates. a little too much, don't you think?
Don't worry bro you can trust @amitgarde3 because once he tells its coming means its coming 😁
Stay tuned for next FOTA!
AmitGarde
Community Legend II
Debasish Sahoo
https://zentalk.asus.com/en/discussion/comment/123013#Comment_123013
Every user has its own way of daily usage so SOT may varie alot on every 5z n yes i agree backup is reduced to some extent i use to get 6.30 hrs of SOT on .70 but now its 1hr less so definetly SOT is reduced and battery needs optimisations
Thanks !
Debasish_Sahoo
Zen Master I
amitgarde3
https://zentalk.asus.com/en/discussion/comment/123099#Comment_123099
Thanks !
Yep agree brother!!😁
BrunoF20
Zen Master I
amitgarde3
https://zentalk.asus.com/en/discussion/37219/5z-minor-and-major-battery-issues
Yeah thats true this is observed for me also on latest .99 but most probably battery issues will get fixed in next FOTA so lets hope this gets fix as well
Even my battery jumps with 2% as soon as i plug in to charge
example :- if i put my 5z on charge at 1% than battery indicating numbers jump like 2&3% instantly within mili seconds and shows 4% charge
also as discribed above in post very true first 10% goes down soon comparing same with last 3% can you look into this as well to fix this with next FOTA @Anders_ASUS @CH_ASUS
Thanks !
There's another minor that when you try to restart your phone with anything less than 3% of charge, it didn't even try but shows it's fully discharged already.
Cheap display, bad sharpness and unstable frequency.
Cheap touch panel, all sort of touch issues.
Cheap energy monitor, bad stats battery reading.
All this and the "well optimized" Android 10!
Ladies and gentlemen! Congratulations! You've bought a "flagcheap"!
