[5Z] Minor and major battery issues!
- The low battery warning option, in the settings, says it will warn the user in 15% and 5%, but warns in 14% and 4%.
- The % indicator does not follow in real time, when it is at 12% in an activity for 10 minutes, it goes down to 11%, but from 11% to 10% it does not last 30 seconds. (Numbers given as an example, do not indicate percentage or time accuracy).
- Sometimes, I put it to charge with 10%, it jumped to 12%, rising to 13%, immediately when connecting.
- The first 10% of battery, after a 100% charge, does not last even the time of the last 3%.
- There is a considerable battery drain after the Android 10. (Not shown on Android 9.)
Comments
Yes, I did all the possible procedures a user can. xD
Yeah thats true this is observed for me also on latest .99 but most probably battery issues will get fixed in next FOTA so lets hope this gets fix as well
Even my battery jumps with 2% as soon as i plug in to charge
example :- if i put my 5z on charge at 1% than battery indicating numbers jump like 2&3% instantly within mili seconds and shows 4% charge
also as discribed above in post very true first 10% goes down soon comparing same with last 3% can you look into this as well to fix this with next FOTA @Anders_ASUS @CH_ASUS
Thanks !
Battery percentage increases as soon as I plugged in my charger ( for example I plug my charger at 77% after 1-2 Seconds it increases to 78% and I tested it for like 10-15 times). @Anders_ASUS
And battery drain issue is there on active usage but mods said that it still will be fixed in upcoming FOTA so nothing to worry about.
M not facing same as u all mentioning, my phone warns me at exact 15% n at 5%.
No sign of jumping battery percentage too. Though i won't let my phone down below 10%.
Bttery degradation maybe the cause of these issues, do a battery calibration n see it works or not.
@amitgarde3 bro do u have any idea about xlzen ui 7 update for 5z?
and Pls keep that thread about zen ui 7 for 5z active guys
"Yes, I did all the possible procedures a user can. xD"
...and my device is relatively new.
Hi friends
Thank you for your reporting. Can you provide me any video for further checking?
U tell us about zen ui 7@Christine_ASUS
This is hard to record because you never know in what percentage it will happen.
When will you find a clear and real solution to battery problems?
Wait for next FOTA it is fully focused on battery optimisations
Coming soon!๐ค
We have always waited for this during the last two updates. a little too much, don't you think?
Until n unless we dont come up with some proofs how was asus suppose to fix this battery issue as per my 5z i still have no complaints on .99 version even .99 give much satisfactory SOT i.e. 5 hrs 30min on my 5z so nothing to complain here and due to this i never took this issue with mods mostly but after seeing other users complaining too much we had some users proofs we took it to mods & dont worry asus have started looking into it as there are various reasons of battery drain which is not by system OS but can be due to third party apps or something
For you if drain is too much you are most welcome to factory data reset and m sure you will see the diffrence and than report here your SOT
Thanks!
But you can't deny the fact that battery drain issue is still there and it needs optimization for sure ;) and I had already sent the logs to mods :)
Don't worry bro you can trust @amitgarde3 because once he tells its coming means its coming ๐
Stay tuned for next FOTA!
Every user has its own way of daily usage so SOT may varie alot on every 5z n yes i agree backup is reduced to some extent i use to get 6.30 hrs of SOT on .70 but now its 1hr less so definetly SOT is reduced and battery needs optimisations
Thanks !
Yep agree brother!!๐
There's another minor that when you try to restart your phone with anything less than 3% of charge, it didn't even try but shows it's fully discharged already.
Cheap display, bad sharpness and unstable frequency.
Cheap touch panel, all sort of touch issues.
Cheap energy monitor, bad stats battery reading.
All this and the "well optimized" Android 10!
Ladies and gentlemen! Congratulations! You've bought a "flagcheap"!
Add one more to it!
I noticed after .99 is if i use screen for above 30 min in landscape mode in any browser for surfing and stream video from any website in browser auto rotation gets stuck screen remains in landscape mode even after holding phone in potrait mode
To rotate screen from landscape to potrait always have to place phone on flat surface and pick it up again n boom as soon as i pick phone up screen automatically rotates instantly to potrait is this a bug ? @Anders_ASUS
