Vibration problem on Zenfone 4 ze554kl
APP Name:
Rooted: No
Frequency of Occurrence: 2.2 GHz
Firmware/APP Version: WW_ZE554KL_15.0610.1909.39
RAM: 4G
ZF Model: ZE554KL
Hi my zenfone has a vibration problem and I dont know it is hardware problem or a bug for my android version because i don't remember is that works or not. How can i know? Please help me for it.
5 REPLIES 5
Y_ASUS
Zen Master I
Hi reza.siami1380, Could you describe the problem for us? Thank you 🙂
Thanks for your replyI bought the phone just 5 days ago and at first i updated it to android oreo, now it's vibration doesn't work and seller says it's because of the update that i did.Now what can i do? Bacause it don't work it testing mode ( calculator =>.12345+= => vibration test) i think that it's not a bug for my firmware or android version. But can you help me to how to convince them?
Y_ASUS
Zen Master I
reza.siami1380 posted on 2019/10/9 15:55 Thanks for your replyI bought the phone just 5 days ago and at first i updated it to android oreo, n ...
Hi reza.siami1380, We would suggest that you ask the reseller about this to make sure if the product could be replaced. Thank you. 🙂
omzavare2000
I have the same problem yesterday  Phone's vibtation is not working. Hardware or software problem?
