05-07-2024 12:34 AM
New Asus zenfone 10... Croatian language...
In the settings under Sound and vibration, it is written incorrectly in Croatian.
Instead of Zvuk i vribracija it should be written Zvuk i vibracija
Please help how to fix it?
Thank you very much!
zlihtar
Solved! Go to Solution.
05-07-2024 04:31 AM
Hi @zlihtar,
Thank you so much for bringing this to our attention. I will be forwarding the issue to the R&D department.
05-07-2024 04:31 AM
Hi @zlihtar,
06-01-2024 09:51 AM
Dear Mansi, I found another grammatical error in the Croatian language on the Asus Zenfone 10. Namely, on the unlock screen (attach) at the bottom it says "Koristi otiska prsta za otključavanje".
"Koristi otisak prsta za otključavanje" is correct, so please if you can report this to the R&D department.
Thank you very much,
Regards,
Zoran Lihtar
05-07-2024 05:05 AM
