2 weeks ago
After the last software update on 19/11/2024, the sound from headphone jack it sounds distorted. I tried through usb to listen from tidal, the problem exists as well. I am listening a lot of music through 3.5 or usb dac and is the first time after the last update that this problem of distorted sound occurs. Please fix it.
Solved! Go to Solution.
2 weeks ago
The solution to the sound problem (Dirac malfunction) came today with the above update from Asus. I checked the BT sound, the 3.5 jack, the speakers, and everything works fine.
Thank you Asus. That proved you hear as and responding asap.
2 weeks ago
Hello, same problem for me
2 weeks ago
same
2 weeks ago
