WiFi issues on Zenfone 10
maskasuba
Does anyone else experience some weird issues while using WiFi on their Zenfone 10s? The internet speed in speedtest.net is great, but for some reason most apps that require a server response (if not all) take forever to load and some are just stuck in a loading screen. If I switch to mobile data then everything loads instantly.
Another weird thing happening is that youtube will sometimes stutter while running in background and using WiFi, no issues on mobile data. Is there a power saving option affecting WiFi? I couldn't find anything.
Mansi_ASUS
Hey @maskasuba,
Can you please share the WiFi log?
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “Wi-Fi ”
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
