Notification bar/panel lag issues
arifsyaifu
Since updating to Android 15, I get this annoying lag issues in the notification panel.
Whenever I tried to scroll or swipe clear the notification is just very laggy and unresponsive
Everything else seems smooth with no problem but it's just the notification that bugged me. Is there any way to solve this?
7 REPLIES 7
johncarter12
Yeah, I’ve noticed this too on my ZF10. The lag when pulling down the notification panel is pretty random but definitely there. Hope it gets smoothed out in the next update it’s small but annoying.
Hello @johncarter12
As mentioned above, this is not happening in a clean android install so there could be something draining the performance in the background, please try some of the steps I wrote to solve this issue.
arifsyaifu
Not sure why but I think I've found the solution
I tried new launcher and now the issue is gone
@johncarter12 If your problem still there, maybe try a different launcher not the default Asus Launcher one and see if it works on you too!
