Not charging battery after shutting down without battery
Da_ny
I was watching youtube and my phone shutted down, it was out of battery. A message advising this situation would be helpful to avoid it.
I connected a charger and turned it on, i continued watching the video and it shutted down again.
I waited for 10 min connected and it do not advanced from 1%. I disconnected all "power master program" and waited for another 15 min, it showed "fast charging" and battery at 1% continuosly.
After connecting to other charger it started to charge. Would be nice if sw can be checked about it. It is not normal that the phone do not charge with the charger i usually use.
Regards
Mansi_ASUS
Hey @Da_ny,
Can you please share a charging log?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
