Zenbook UX325EA Intel Management Engine vulnerabilities
Ocelot5926
It appears that Intel's Management Engine on the Zenbook 13 UX235EA is vulnerable to a few exploits:
https://www.intel.com/content/www/us/en/support/articles/000031784/technologies.html
The laptop has the latest BIOS version available (BIOS UX325EA.317 08/09/2022), and seems to come with Intel Management Engine version 15.0.35.1951 (which Intel says is vulnerable, see link above)
Does anybody know how to obtain a newer version of Intel's Management Engine for this laptop?
Thanks in advance.
7 REPLIES 7
Falcon_ASUS
@Ocelot5926
I have forwarded the information to the relevant department.
We will keep you updated and your consideration will be very much appreciated.
Thank you!
@Ocelot5926
I'm here to update you on the progress of the case.
Regarding the situation you reported, we are planning to release a new version of BIOS in mid-July.
If there are any further updates, I will promptly report them to you.
Ocelot5926
Thanks for the heads up, @Falcon_ASUS
