Zenbook Q425MA Audio Drivers go out after few minutes
timlawder
After I restart my laptop my audio drivers are working just fine, for both my headphones and speakers but eventually they cutout. This usually when I switch the source of the audio. For example if I am playing music on spotify, and I pause it and go to youtube (or ableton, or any other source of sound), it cuts out for everything. And the only way to fix it is by restarting my laptop, just to run into the same issue. I have tried updating my drivers, unistalling/reinstalling, and have not had any luck.
Falcon_ASUS
@timlawder
If you have already tried reinstalling the driver but the issue persists, we recommend backing up your data and restoring the system to determine if the problem is resolved. This will help rule out any potential system faults.
[Windows 11/10] How to Reset (Reinstall) the Operating System
