Zenbook Pro Duo with PA148
theamascope
System: Windows 11 64 bit
Battery or AC: AC
Model: Zenbook Pro Duo UX582
Frequency of occurrence: always
Reset OS:
Screenshot or video:
Detailed description:
Hi everyone,
I have acquired a couple of Pro Art PA148 screens to enhance my workflow. Monitor detection works fine, but whenever I try to use the touch function on the PA148 it executes on the main Zenbook Pro Duo display. I guess the driver needs a way of identifying which screen the touch commands belong to?
Pro Art software recognised the monitor and has shown a separate tab for it.
Didn't try with both PA148 monitors 🙂
Suggestions?
Thanks
Falcon_ASUS
theamascope
  1. System: Windows 11 64 bit
  2. Battery or AC: AC
  3. Model: Zenbook Pro Duo UX582
  4. Frequency of occurrence: always
  5. Reset OS:
  6. Screenshot or video:
Hi everyone,
Suggestions?
Thanks
@theamascope
Could you please provide me with a video of your entire operation for confirmation?
Also, what is the full model of the laptop you are using?
What is the BIOS and system version you are using?
[Notebook] How to check the model name and BIOS version | Official Support | ASUS GlobalWhich version of Windows operating system am I running?Sorry for any inconvenience it may be caused.
ASUS_Bot
Rising Star II
