10-03-2020
07:08 AM
- last edited on
01-16-2024
12:40 AM
by
ZenBot
10-04-2020 04:54 AM
10-05-2020 01:31 AM
daniktherrienDocks made by Dell , will be compatible with Dell high valued laptops .
- System: UX581GV
- Battery or AC: AC
- Model: Version 10.0.18363 Build 18363
- Frequency of occurrence: ALL the Time!!
- Reset OS: windows 10
- Screenshot or video: none
Detailed description:
I bought 3 thunderbolt docks because my Dell D6000 with display ports made the GPU go to 100% all the time.
Now as the third dock I have a Dell WD19TB with two Display Port Screens connect to it.
I tried with HDMI as well and I can't seem to have the two screens work in 4K or even in HD.
Is there a reason why I can't use the two external screens using Display Port?
Docks I've tried CalDigit TS13, Elgato Pro Dock and Dell WD19TB.
ZenBook Pro Duo doesn't work with dual displayport screens and Thuderbolt 3 dock
10-05-2020 01:38 AM
10-05-2020 01:42 AM
daniktherrienSome thunder bolt port will work to connect External GPU.Thank you for your reply, not sure if you completely red my post, but I tried Caldigits and Elgato as well.... I have the EXACT SAME Behavior.
