04-06-2021 01:51 AM
04-06-2021 07:17 AM
jacksonpirates82You need to check the battery power energy report, so that we will tackle which applications are running background.Hey guys. Last week I bought a brand new ASUS ZenBook 14 with Ryzen 7 4700u CPU and Nvidia MX350 GPU. Everything with the laptop is good except for one issue I have.
When I put the laptop on sleep for an extended period of time (eg. over 40-60min) once it wakes up the fan is blasting on full speed and does not stop until I hibernate or turn off the system. There are no heavy processes running, CPU temperatures are just a little above ambient so it is not overheating for sure.
I updated everything I can from the Asus app, did all available windows updates, running on the latest BIOS, downloaded the AMD latest drivers from the website but the issue still exists. From what I could find online some people are experiencing the same issue and a workaround suggested is to make the laptop go to hibernate instead of sleep when you close the lid or press the power button, but it is just a workaround, does not solve the issue.
Any advice is appreciated.
ZenBook 14 UM433I sleep mode fan issue
04-06-2021 07:56 PM
