Zenbook 14 OLED UX3405 - Charger 65w or 90w?
Ktly
I heard some boxes come with 90w charger instead 65w charger. Mine is 65w. Any reason? and any positive impact on using with 90w charger?
Mine is Ultra Core 9 185H , 32gb ram with 1tb SSD.
Thanks.
Falcon_ASUS
@Ktly
Could you please provide the full model of the laptop you are using?
How to find Model Name
The specifications of the laptop are based on the actual shipped product.
It is "UX3405MA-PP287W"
@Ktly
The wattage of the charger used should be equal to or greater than the wattage of the original charger, but please make sure to use the charger provided by us.
Regarding the specifications, we suggest referring to the following:
https://www.asus.com/laptops/for-home/zenbook/asus-zenbook-14-oled-ux3405/techspec/
