UX482EA power light constantly on, but the device won't turn on
jpfwbw
System: Windows 10
Battery or AC: Both
Model: Zenbook UX482EA
Frequency of occurrence: Always
Reset OS: Impossible
Screenshot or video:
Detailed description:Hello guys.
So that's quite the unique issue I'm facing right now. I was using my laptop when it randomly shut down. When I tried to turn it back on, the power light turned on but the laptop didn't react at all.
And that's when the truly weird stuff happened. Basically, the power light is constantly on, unless I press the power button for roughly 15-20 seconds, then it will turn off until I release the button. Whenever I release the button it seems like the laptop tries to turn on automatically (to no avail).
Sometimes, another situation happens. The power light turns off, and pressing the button won't change anything. I then have to plug the laptop for to, again, turn on automatically.
I can't explain how, but after hours and countless trials, the laptop turned on for a minute only to shut down once again and go back to the aforementioned situation.
I know it sounds really unclear, but it's hard to put words on what's happening. Anyways, I'd appreciate if you could give me some tips and things to try.
Thanks
5 REPLIES 5
ASUS_Bot
Rising Star II
