Detailed usage guide of VivoBook
Rahul_Mark
ASUS VivoBook is a laptop that can be used for almost anything. It's durable and has an excellent battery life, so you can take it anywhere you need to go. Here are some tips on how to use your ASUS VivoBook:
• Charge your ASUS VivoBook before using it. If you don't, the battery will run out quickly and you'll have no way to use your device.
• When charging your ASUS VivoBook, make sure that it's plugged into an outlet instead of just being plugged into the wall with a USB cord. This will help charge your device faster and protect it from damage from overcharging.
• If you're using your ASUS VivoBook at home or in a place where there's free Wi-Fi available, turn off Bluetooth and Wi-Fi so that they aren't constantly searching for networks or devices that could interrupt work flow while using them. This will also help save battery life because those features require more energy than others do when turned on all day long without being used often enough for them to recharge fully before needing again later on down the road months later when needed again!
0 REPLIES 0
