UX434FL Supports External Display Through USB-C?
System: Windows 10
Battery or AC:
Model: UX434FL i7 8564U
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:So, I saw in another thread https://zentalk.asus.com/en/discussion/30478/does-the-usb-c-adapter-on-a-zenbook-14-support-display-...
that USB-C does not support video export for a secondary display. However, someone mentioned that is usable for DisplayPort, I have a USB-C to HDMI cable and also an adapter from anker, but none of it works with the monitor, saying that "Displayport capabilities or USB capabilities might be limited"...
It's been 2 days I'm searching for this and already bought these cables that I'll have to return bc it doesn't work...
I'm almost trying to find a normal USB 3.0 HUB that has HDMI so I can use another display (I already use the HDMI output for my first monitor).
So, whats the use of the USB-C port if doesn't allow Thunderbolt 3 / Alternate mode?
Am I missing something here? Is there a way I can export video through that port?
0 REPLIES 0
