UX325 Battery Wear
gabrio81
These are my battery stats for my UX325, it's 6 months old, i really like the little monster... is the battery on the aging side already? my stats
so there's about 15% battery wear, have done 4 calibrations down to 0 and back, actually found a neat way of doing it via BIOS, just leave it running and really drains the battery well.
Anyhow, 14.7% is that a normal wear or on the high side? It does i think 8-9 hours in balanced. High Performance (4.4 ghz) about 3-4 hours.
thanks,
Gabrio
Falcon_ASUS
gabrio81
thanks,
Gabrio
UX325 Battery Wear
@gabrio81
If you are concerned about the battery health of your laptop, I would suggest you to bring back your laptop to our service center.
http://www.asus.com/support/Service-Center-All-Countries/
Also you can contact the local service center for help. The following is the contact information:
http://www.asus.com/support/CallUs#
gabrio81
Well it's not that bad, i was just wondering if anybody else experienced the same wear levels.
