using powerbank for charging
saara55
System: win 10
Battery or AC: 65wat
Model: ZenBook 14 UX425ea
Frequency of occurrence:
Reset OS:
Screenshot or video:
hello:
Is it possible to charge the device via a Power Bank?
because When I charge it with a battery-less than 65 Watt, a message appears that charging is slow
But if I charged it with a 65watts battery higher, it would charge normally, is this normal?
Thank you
6 REPLIES 6
RAJU_MSC_MATHEM
Zen Master I
saara55
  1. System: win 10
  2. Battery or AC: 65wat
  3. Model: ZenBook 14 UX425
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
hello:
Thank you
power adapter 65w gives input 19.5 V
but Powerbank gives input 4.2V ..
so I would recommend you use only Power adapter that comes with you your laptop.
saara55
Thanks for the reply... The meaning of this the device normal no issues
RAJU_MSC_MATHEM
Zen Master I
saara55
I have not tested using this method.
Blake_ASUS
Community Legend II
Hello saara55,
Your model requires power input at least 65W to run stably, or it will switch to use it's own battery.
So please use a power bank that is able to export 65W.
Thank you very much.
