OLED screen quality
gszkop
System: Windows 10
Battery or AC: AC
Description: OLED screen quality
Model: Asus Zenbook Pro Duo
Frequency of Occurrence: Always
Reset OS: No
I bought Zenbook Pro Duo and the first thing that caught my eye was the uneven backlight of the screen. When displaying e.g. 5% gray, using a video on YouTube at this link https://www.youtube.com/watch?v=Qi4Wy7vE8-o&t=124s and reducing the screen backlight, you can see a large unevenness in the brightness of the backlight. I will point out that the problems I describe can be seen best in a dark room, when working during the day the problems are not visible or are very poorly visible.
48 REPLIES 48
gszkop
I am most annoyed by the bright horizontal streak in the middle of the screen, which I see on dark backgrounds (regardless of the brightness of the screen) working in the dark. I already had three UX581 laptops, in the previous two there was a significant difference in brightness between the left and right sides of the screen.
braintheboss
gszkop posted on 2019/11/11 15:28 I am most annoyed by the bright horizontal streak in the middle of the screen, which I see on dark b ...
Maybe smarter way is send to repair. As they have check issue is solved then you should get one fine
gszkop
and yours already returned from repair?
braintheboss
gszkop posted on 2019/11/11 21:10 and yours already returned from repair?
They told is repaired. But not idea what they do. Tomorrow I will receive. I think they only repaired banding problem. I don't think grain have solution
gszkop
write after receiving and checking.  You didn't ask what exactly they did?
