There is something wrong with yours. I tried on mine and if I slide my finger on the pad, it does move the cursor, but I can still insert numbers. So, it's like 2 in 1 at the same time. When I have it on trackpad mode, it works only as a trackpad, no interference. So, everything is running normal on my side. You should fill the small form from your post with all the details.
