02-26-2022 09:15 AM
02-28-2022 10:37 PM
aau aau@aau aau
- System: Windows 11 and Windows 10
- Battery or AC: BOTH
- Model: UX482
- Frequency of occurrence: ALWAYS
- Reset OS: TRIED
- Screenshot or video: nope
Detailed description:INTEL Display Power Saving Technology changes screen brightness/contrast/gamma/sharpness for battery saving. It can be turned off using INTEL GRAPHICS COMMAND CENTER, but it is doing so only for the main screen and not for the second smaller screen on my laptop. Is there anything i can do about this? Documents on a dark background are not readable and are causing eye strain.
INTEL DPST for Zenbook Duo
Falcon_ASUSThank you.You can do this by disable "Panel Self Refalsh" & "Display Power Savings" options.
