System: Windows 10 Battery or AC: AC Description: Grey lines and green flicker on webcam when using AC power Model: UX533FD Frequency of Occurrence: Always Reset OS: No
As described above, the webcam image has grey lines and occasional green flickers. This only occurs when AC power is plugged in, everything works perfectly when using battery. I have removed and re-installed drivers with no success.
This is a brand new laptop that I removed from the box yesterday.
I see that there are two other questions with the same issue, but no answer has been provided. Is this a hardware issue and do I need to return my laptop or is there a software fix?
Hey @Blake_ASUS , I'm having the same issue and unfortunately I have a university exam in a couple days which is proctored aka needs the webcam on, could you send me the bios that fixes it if one exists? My laptop model is Asus VivoBook S15 S512FL-BQ279T
