Can not charge Zenbook 14 UX425J - Maybe Power Delivery FW upgrade?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-29-2021
05:48 AM
- last edited on
01-16-2024
01:51 AM
by
ZenBot
Battery or AC: AC
Model: UX425J i5-1035G1
Frequency of occurrence: Always (after Update?)
Reset OS: No
Screenshot or video:
Detailed description:
Hello!
I have set up a new ASUS Zenbook 14 UX425J. After all Updates from Windows Update I installed also all Updates from the Driver Site. Now I can't charge it anymore and both USB-C ports a dead - is it possible that the Power Delivery FW upgrade V1.0 is not compatible? Why would it install then?
In Device-Manager the USDB-Device USM-USCI ACPI-Device is not functioning and the charing LED is of. I tested the charger on another device (it's working) and another charger without luck.
I reseted the bios to defaults and did a reset by pressing the button more than 50 sek.
PS: I have just 35% battery left. This device can only be charged via USB-C
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-08-2021 07:16 AM
I have the same problem as described above. I have a new ASUS Zenbook 14 UX425J, it work fine till last week. It indicates that the battery is 100% and is charging however the laptop does not work with the adapter connected.
When I see which battery drivers I have I only have the Microsoft ACPI-Compliant Control Method Battery, could the problem be that I miss the AC Adapter driver?
Any other ideas?
Thanks in advance.
Teun
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-08-2021 06:55 PM
Was there any update before the issue occurred? like BIOS or you also install that Power Delivery FW?
You may try to long press the power button for 40 seconds to reboot the device.
Let me know the result.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-09-2021 05:30 AM
Thanks for the quick answer. I did not install anything myself and check/updated all the drivers/Bios etc in the previous days, also tried the 40sec reboot it does not seems to do anything. Yesterday I reinstalled windows, which if I installed (power delivery FW) something wrong should redo this, right? However it did not work.
Any other advise?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-10-2021 03:39 AM
teunvanerpNo need to install AC adapter driver to install.Hi Blake,
Any other ideas?
Thanks in advance.
Teun
Windows will manage automatically to charge battery
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2021 07:23 PM
If you did install the wrong FW, it can not be redo. It's not a simple software.
Please enter BIOS, and load default setting again.
Hope it would work this time for you.
