Battery drain during sleep (modern standby)
jplhzn
System: W10 Pro
Battery or AC: Both
Model: ASUS ZenBook Flip 14 UX461UN
Frequency of occurrence: always
Reset OS: done : clean install
Screenshot or video: N.A
Detailed description:
Hi, since the begining I have issues with my laptop in sleep mode. The battery drain because of the modern standby mode.
I followed the procedure here to disable the modern standby : asus.com/support/FAQ/1035447/
But now my computer doesn't wake up when in sleep. It's incredibely annoying.
How can I fix that ?
Thank you and have a nice day,
Jérôme.
17 REPLIES 17
Blake_ASUS
Community Legend II
Hello Jérôme,
If you did not plug in AC, I would say 1% every 45 min sleep now seems normal.
If you wish to save more power, maybe set your device to hibernate after sleep mode for a while.
Also, please double check if your Windows has updated to 1909 and complete all the KB update.
RAJU_MSC_MATHEM
Zen Master I
jplhzn
Hello Blake, thank you for your answer.
You will find the reports in attachment.
I disabled the wifi during sleep, so now I "only" loose 1% each 45 minutes in sleep.
Thank you for your precious help,
Jérôme.
https://us.v-cdn.net/6031231/uploads/645/V3C04IKSK2S1.zip
Reasons for Battery drains could not be found out. I need to analyis other report ,say energy report for 5 minutes.
I will give you command after your reply
jplhzn
Hello, sorry for the delays, I didn't received the notifications about the answsers.
W10 is fully updated, the battery drain during sleep is now acceptable.
Raju, could you tell me what report you need and how I can get it ?
Thank you a lot for your help,
Jérôme.
RAJU_MSC_MATHEM
Zen Master I
jplhzn
Jérôme.
type below lines in command prompt with admin rights , zip all the reports and upload
powercfg.exe /ENERGY -output C:\Energy-Report27-04-2020.html /duration 300
powercfg.exe /BATTERYREPORT -output C:\Battery-Report27-04-2020.html /duration 14
powercfg.exe /SLEEPSTUDY -output C:\Sleepstudy-Report27-04-2020.html /duration 14
powercfg.exe /SYSTEMSLEEPDIAGNOSTICS -output C:\systemsleepdiagnostics-report27-04-2020.html /duration 14
powercfg.exe /SYSTEMPOWERREPORT -output C:\Systempower-Report27-04-2020.html /duration 14
powercfg.exe /SRUMUTIL -output C:\Srumutil-Report27-04-2020.html
jplhzn
Hello, sorry again for the delay.... I'm over busy because of the actual situation.
Here are the reports, thank you a lot for your help !
All the best,
Jérôme.
