11-07-2023 10:35 AM
Just wanted to know if anyone else on here has an ASUS Zenbook Flip S13 UX371EA and what you think of the battery life.
The spec I have is ASUS Zenbook Flip S13 UX371EA 13.3" 2 in 1 Laptop - Intel® Core™ i7, 1 TB SSD, Black, and the claimed battery life is 10 hours. Now I knew I'd never get 10 hours, but from new out of the box and only web browsing I only get about 4 hours and I have screen brightness low and the battery mode on "best power efficiency" and have all the eco-recommended settings on.
What battery life are others getting?
11-07-2023 05:11 PM
@Marcher
Did you buy the OLED version or not?
The following is the specification information of the OLED version for your reference.
https://www.asus.com/laptops/for-home/zenbook/zenbook-flip-s13-oled-ux371-11th-gen-intel/
10.Battery tests conducted by ASUS on August 18, 2020 using the MobileMark® 2018 Office Productivity scenario. Test configuration: ZenBook Flip S13 UX371EA, 4K OLED HDR panel, Intel® Core™ i7-1165G7, 1 TB PCIe® 3.0 x4 SSD, 16 GB RAM. Test settings: WiFi enabled, the display brightness set to 150 cd/m2, NumberPad off. Actual battery life may vary depending on product configuration, usage, operational conditions and power management settings. Battery life will decrease over the lifetime of the battery.
11-07-2023 10:09 PM
Yes, it's the OLED version.
11-08-2023 10:15 AM
@Falcon_ASUSwhat level of battery life would you expect me to be getting out of the box and just browsing on 30% brightness? Are there any diag tools I can run to check my system on why the battery life is so poor?
Battery
11-08-2023 11:03 AM - edited 11-08-2023 11:06 AM
As above would expect a lot more than 3 hours battery.
