11-13-2020 03:44 PM
11-18-2020 07:24 AM
11-18-2020 07:44 AM
eliaz.brumerI seen the picture, battery is too good and new..
here it is
11-18-2020 07:55 AM
11-18-2020 08:30 AM
eliaz.brumerthanks for the detailed informationthe battery is new due to two reason - it is a new laptop - 1.5 month and the second is that the battery was replace 2 weeks ago by ASUS lab technician - as the battery barely worked - and they found out that it was swollen and had to changed it. So My though that it may be a problem in the motherboard or something that control the battery.
here all the information - if you need anything else just tell me where to find it
that you
OS Name Microsoft Windows 10 Pro
Version 10.0.18363 Build 18363
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name LAPTOP-M635S51R
System Manufacturer ASUSTeK COMPUTER INC.
System Model ZenBook UX434FLC_UX434FL
System Type x64-based PC
System SKU
Processor Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz, 2304 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. UX434FLC.306, 15-May-20
SMBIOS Version 3.2
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Product UX434FLC
BaseBoard Version 1.0
Platform Role Mobile
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "10.0.18362.1171"
User Name LAPTOP-M635S51R\eliaz
Time Zone Eastern Standard Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.8 GB
Available Physical Memory 12.0 GB
Total Virtual Memory 18.7 GB
Available Virtual Memory 14.4 GB
Page File Space 2.88 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
IRQ 109 I2C HID Device
IRQ 109 Microsoft ACPI-Compliant System
IRQ 16 Intel(R) Dynamic Tuning Processor Participant
IRQ 16 Intel(R) Serial IO I2C Host Controller - 02E8
Memory Address 0xC3000000-0xC3FFFFFF NVIDIA GeForce MX250
Memory Address 0xC3000000-0xC3FFFFFF Intel(R) PCI Express Root Port #5 - 02BC
Memory Address 0xA0000000-0xDFFFFFFF PCI Express Root Complex
Memory Address 0xA0000000-0xDFFFFFFF Intel(R) UHD Graphics
Memory Address 0xB0000000-0xBFFFFFFF NVIDIA GeForce MX250
Memory Address 0xB0000000-0xBFFFFFFF Intel(R) PCI Express Root Port #5 - 02BC
Name NVIDIA GeForce MX250
PNP Device ID PCI\VEN_10DE&DEV_1D52&SUBSYS_150F1043&REV_A1\4&1D68CD4A&0&00E4
Adapter Type GeForce MX250, NVIDIA compatible
Adapter Description NVIDIA GeForce MX250
Adapter RAM (2,147,483,648) bytes
Installed Drivers C:\WINDOWS\System32\DriverStore\FileRepository\nvam.inf_amd64_c436e4f86f7beadc\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvam.inf_amd64_c436e4f86f7beadc\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvam.inf_amd64_c436e4f86f7beadc\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvam.inf_amd64_c436e4f86f7beadc\nvldumdx.dll
Driver Version 26.21.14.4294
INF File oem89.inf (Section012 section)
Color Planes Not Available
Color Table Entries Not Available
Resolution Not Available
Bits/Pixel Not Available
Memory Address 0xC0000000-0xC1FFFFFF
IRQ Channel IRQ 4294967274
Driver C:\WINDOWS\SYSTEM32\DRIVERSTORE\FILEREPOSITORY\NVAM.INF_AMD64_C436E4F86F7BEADC\NVLDDMKM.SYS (26.21.14.4294, 22.19 MB (23,272,176 bytes), 12-Oct-20 22:52)
Name Intel(R) UHD Graphics
PNP Device ID PCI\VEN_8086&DEV_9B41&SUBSYS_150F1043&REV_02\3&11583659&1&10
Adapter Type Intel(R) UHD Graphics Family, Intel Corporation compatible
Adapter Description Intel(R) UHD Graphics
Adapter RAM 1.00 GB (1,073,741,824 bytes)
Installed Drivers C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a15faa87237524bb\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a15faa87237524bb\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a15faa87237524bb\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a15faa87237524bb\igd12umd64.dll
Driver Version 26.20.100.7870
INF File oem101.inf (iCML_w10_DS section)
Color Table Entries 4294967296
Resolution 1920 x 1080 x 60 hertz
Bits/Pixel 32
Memory Address 0xC2000000-0xC2FFFFFF
I/O Port 0x00004000-0x0000403F
IRQ Channel IRQ 4294967273
Driver C:\WINDOWS\SYSTEM32\DRIVERSTORE\FILEREPOSITORY\IIGD_DCH.INF_AMD64_A15FAA87237524BB\IGDKMD64.SYS (26.20.100.7870, 23.45 MB (24,591,928 bytes), 12-Oct-20 22:56)
Name Citrix Indirect Display Adapter
PNP Device ID PCI\VEN_5853&DEV_1003\1&79F5D87&0&03
Adapter Type Not Available, Citrix Systems Inc. compatible
Adapter Description Citrix Indirect Display Adapter
Adapter RAM Not Available
Installed Drivers Not Available
Driver Version 12.40.44.247
INF File oem43.inf (ViddDev_Install.NT section)
Resolution 504 x 1000 x 50 hertz
Bits/Pixel 32
Driver C:\WINDOWS\SYSTEM32\DRIVERS\WUDFRD.SYS (10.0.18362.1, 291.00 KB (297,984 bytes), 18-Mar-19 23:44)
11-18-2020 08:38 AM
eliaz.brumergo to below site , download CSME_Version_Detection_Tool_Windows 4.0.1.0 windows version , unzip the filethe battery is new due to two reason - it is a new laptop - 1.5 month and the second is that the battery was replace 2 weeks ago by ASUS lab technician - as the battery barely worked - and they found out that it was swollen and had to changed it. So My though that it may be a problem in the motherboard or something that control the battery.
that you
System SKU
SMBIOS Version 3.2
BIOS Mode UEFI
Bits/Pixel 32
Bits/Pixel 32
